Yes No
Ads
Tom's Hardware > Forum > Graphics & Displays > Graphics Cards > [Solved] Gigabyte gts 250 heat problem
Forum Graphics & Displays : Graphics Cards [Solved] Gigabyte gts 250 heat problem
Best answer from ct1615.
hey guys i wanna ask a few question.. i bought gigabyte gts 250 1gb n i'm worried about the heat recently i play a lot of pc gaming n my heat goes up to 80 to 82c n when i'm idle the heat stay at 50 to 53c is it normal or should i worried about the heat..plz help me coz i dont wanna spend money on my pc anymore coz im broke rite now lolz..btw im from malaysia n as u guys know our weathers is always hot n unpredictable..
Reply to scarky
those are normal operating temps for the card, my GTS idles at 60c and hits 80c at load
------------------------------ defeating idiot fan boys since 2008.
Reply to ct1615
owh thanks for the reply dude ,and can i know what is the max temp that gts 250 can reach before it burn to hell.. = p ??
Reply to scarky
It's still normal...
Just make sure it doesn't reach above 90'C. :)
Reply to wa1
Best answer
they can hit 110c+ and still work fine, although if you do break 100c i would recommend better cooling
Reply to ct1615
erm..i see now,can you suggest to me the best cooling hardware for cpu and gpu before i go to liquid cooling??
Reply to scarky
there are a lot of options
add an extra fan
better cable management in a case for airflow
use better thermal paste and re-seat the the cpu/gpu heatsinks
upgrade coolers for the cpu/gpu heatsink
unless you want to push overclocking or your PC is having issues due to overheating, I would not go crazy about cooling. Often an extra fan and cable management will do the trick for a stock PC & parts.
Reply to ct1615
what is the best coolers brand should i get if i wanna buy one for my cpu/gpu??
Reply to scarky
There are 1662 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Difference in these cards is only the factory OC right?
By fantastik250, 1 hour ago:
I should say that is the only difference.
Best offers
Top experts
