Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Power Supplies, Cases & Mods > 24pin power supply into 20pin motherboard
Forum CPU & Components : Power Supplies, Cases & Mods 24pin power supply into 20pin motherboard
Hello,
My computer has a Biostar P4M80-M4 motherboard. I am replacing the damaged 20pin 550w ATX power supply. They sent me a new 24pin 600w replacement. I notice that the 24pin connector is an assembly consisting of a 20pin part plus a snap-on 4pin part that can be detached from the 20pin. I suppose this 4pin component is detached to allow insertion of the 20pin connector into the 20 pin motherboard power connector. All the wires on both 20 pin connectors (old 20pin connector and 20pin component of the new power supply) are same colors on same pins, except that on the new supply there is no white cable ( on pin #18 and there are a red and a pink cable on pin #20). Can anybody tell me if this power supply will work o.k. just plugging-in the 20 pin component, do I have to modify the connections or use an adapter?
Reply to Anonymous
The 20+4 are usually completely compatible with the older 20-pin motherboards.
Assuming when you are naming the pins you are only naming the ones on the 20 pin segment:
Pin 18 is a no-connection pin, so there is no problem if a cable does not run here.
Pin 20 is a +5v pin, and should be red in color. If it is red and pink, this is likely a coloring defect in the plastic - if this is true, you probably have a red and pink mottled color.
If I am incorrect in any of my assumptions, let me know, and we'll go from there.
------------------------------ Useful technology causes useless people
Reply to user 18
The 24 pin power supply is always pin compatible with a 20 pin board. The first 20 pins are the same. The extra 4 are to provide additional power for PCI Express. If your board doesn't have them, then it doesn't need them.
Reply to FALC0N
You will be fine, just attach that 20pin from PSU to the board, don't worry about that. :)
Since your board only need 20pin then don't bother with the extra 4pin, the newer board use 24pin and the older board has 20pin.
------------------------------ Core 2 Duo E6300 1.8 GHz (OC at 3.0 GHz) / Zigmatek HDT S1283 CPU Cooler / Gigabyte GA 965P-DS3 Motherboard / 2x1 GB DDR2 800 RAM / 2x160 GB Seagate HDDs / SilverStone ST50F 500W PSU / HIS IceQ 4 HD 4850 512 MB DDR3 / 17" LG Monitor
(Little Dinosaur)
Reply to wa1
There are 1677 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
CPU fan
By mocchan, 1 hour ago:
Your case has a cut out for a backplate to be installed, so you SHOULD be fine installing...
Best offers
Top experts
