Hyper 212 with SILVERSTONE FM121 120mm Case Cooling Fan
Pretty simple question, my Hyper 212 fan has died and I'm wondering if I can put a SILVERSTONE FM121 120mm Case Cooling Fan on it as a replacement.
Basically.... will this: http://goo.gl/4JagC fit on this: http://goo.gl/Aac9J
It looks like they are the same size and I can switch on the bracket, but I'm concerned about the fan speed control. It says this is a case fan, but shouldn't it work on cpu cooler?
2 answers Last reply
More about hyper silverstone fm121 120mm case cooling
  1. Hi,
    Yep you can replace the fan if needed, this was taken from the Hyper 212 description:
    "QUICK SNAP FAN MOUNTING
    Utilize the included brackets to quickly add or remove fans for upgrades, replacement, or maintenance."
  2. I would make sure its a 4 pin fan so it can go on your mobo.. you don't want it running at 12V all the time.
Heatsinks Silverstone Cooling Fan Cases Overclocking
