N nanse kiyle Honorable May 7, 2012 5 0 10,510 May 8, 2012 #1 Hello, what is a subsection for my answer on how to remove the U3?
Solution WyomingKnott May 8, 2012 Assuming that this is a Sandisk USB flash drive, try this: http://u3.sandisk.com/launchpadremoval.htm
WyomingKnott Legenda in Aeternum Aug 29, 2006 13,249 3 51,960 May 8, 2012 Solution #2 Assuming that this is a Sandisk USB flash drive, try this: http://u3.sandisk.com/launchpadremoval.htm Upvote 0 Downvote Solution
N nanse kiyle Honorable May 7, 2012 5 0 10,510 May 18, 2012 #3 Best answer selected by nanse kiyle. Upvote 0 Downvote
N nanse kiyle Honorable May 7, 2012 5 0 10,510 May 18, 2012 #4 WyomingKnott : Assuming that this is a Sandisk USB flash drive, try this: http://u3.sandisk.com/launchpadremoval.htm Upvote 0 Downvote
N nanse kiyle Honorable May 7, 2012 5 0 10,510 May 18, 2012 #5 nanse kiyle : Best answer selected by nanse kiyle. n n WyomingKnott : Assuming that this is a Sandisk USB flash drive, try this: http://u3.sandisk.com/launchpadremoval.htm n nNone of the methods suggested worked on my mac. Upvote 0 Downvote
WyomingKnott Legenda in Aeternum Aug 29, 2006 13,249 3 51,960 May 18, 2012 #6 You have to tell us that it's a Mac! That's a different kettle of fish from what we usually do. Can you borrow a Win PC and run the sansa utility? Upvote 0 Downvote
N nanse kiyle Honorable May 7, 2012 5 0 10,510 May 18, 2012 #7 Cannot borrow a PC to run the sansa utility. Could not reformat the unit using Mac Disk utility. Since it does run on the Mac I will use the unit as a temporary carrier of data only. Upvote 0 Downvote
WyomingKnott Legenda in Aeternum Aug 29, 2006 13,249 3 51,960 May 18, 2012 #8 Sorry that it's inconvenient. I found U3 sort of annoying myself. My daughter had one; that's how I know where the tool to remove it was. Sandisk makes magnificent music players, though. So they are not all bad. Upvote 0 Downvote
D daveN_61 Honorable Aug 29, 2012 1 0 10,510 Aug 29, 2012 #9 WyomingKnott : Assuming that this is a Sandisk USB flash drive, try this: http://u3.sandisk.com/launchpadremoval.htm Excellent!! thank YOU!!!! Upvote 0 Downvote
