CPU Cooler Help.
Hi,
I have an i5 2500k at stock 3.3Ghz speed. I am wanting to overclock it now so I have been looking at some aftermarket CPU fan/heatsink. I am worried about the size of this because when looking inside my case and where the CPU is, it doesn't look like I have much room.
Here is the CPU cooler I am looking at. http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
My Case - http://www.newegg.com/Product/Product.aspx?Item=N82E16811129066
Motherboard - http://www.newegg.com/Product/Product.aspx?Item=N82E16813131837
Does anyone else have this same setup or know for sure if this will fit?
Thanks for the help.
2 answers Last reply
More about cooler help
  1. Evo is 6.2 inches high
    Your case is 8.1 inches wide
    It will fit!
  2. The Xigmatek Gaia is only $20 right now: http://www.newegg.com/Product/Product.aspx?Item=N82E16835233082 and cools within 1C of the Crappermaster per Frostytech reviews. It is also quieter. I have two of them, and it keeps my overclocked AMD 970BE nice and cool; I haven't checked in a while but I think I hit 42C during some games (idle at 29C-32C depending on season). Why spend more?
Heatsinks Overclocking Cooling Cases Intel i5 CPUs Product
