Hello everybody! Thanks in help in advance. I am new!
So I am in currently looking at making my own first system.
Currently I have:
Mobo: ASUS A8N-E
CPU: AMD Athlon 64 3000+ 1.81gz
RAM: 1 gb DDR
OS: Windows XP
I am looking to make a much better system. This is what I'm looking at upgrading too:
Mobo: http://www.newegg.com/Product/Product.aspx?Item=N82E16813138179
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819103644
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820313081
Note: I'm lookin at spending around $250 or so.
So my first question is, should I buy a new motherboard because my current one doesn't support DDR3 RAM? How much better is DDR3 than DDR?
My current motherboard says it is compatible with AMD Phenom II x4 on the box.
The CPU I am wanting to upgrade to doesn't include a heatsink/fan. Any suggestions on a good heatsink and fan for that CPU? 4 cores, it'll be runnin hot !
Finally, I just want to make sure everything is compatible and will work!
Thanks for the help!
Dave
Currently I have:
Mobo: ASUS A8N-E
RAM: 1 gb DDR
OS: Windows XP
Dave
