Hi,
I'm trying to install Win XP Pro on a Raid 0 and i use a USB stick to load the drivers i keep getting the error: Insert disk labeled AMD AHCI Compatible RAID Controller Driver Diskette after the RAID 0 is recognized,partitioned and formatted. The BIOS has been configured (latest rev) in USB configuration mode to run on 'Force FDD'. The error message appears just before the files would start to be copied onto the HDD (i.e. RAID).Tried formatting the USB stick as a 1.44 floppy and copy the drivers onto it and modified the USB config in BIOS to Floppy but same result.
If anyone had the same issues please advise
Thank You in advance
System
AMD1090T, Crosshair Extreme, Ripjaws 8Gb CL7, 2x Corsair Force F40Gb in Raid 0,
System
