Hello, I am new to Tom's hardware, and I hope that toms hardware can help me with my problem.
For the past couple of days I have been building a computer from parts my uncle gave me as well as some I had gotten from the internet. My uncle supplied the motherboard, processor, mouse and keyboard, while I supplied everything else.
For explanation reasons, my motherboard is this (http://www.newegg.com/Product/Product.aspx?Item=N82E16813135233&Tpk=A780GM-m3)
While my processor is an AMD Athlon II X2 250 processor (3.0 Ghz)
Anyway, I have been experiencing trouble with getting the monitor to respond to the computer. At first I thought it was the video card I purchased (radeon 5770), I then decided to take it out and try to use the on board video card on the motherboard, but the screen continues to get no signal. I then thought it was the actual screen so I tested it on another monitor and it still doesn't work!
For the record, my power supply is more than capable of running this machine (http://www.newegg.com/Product/Product.aspx?Item=N82E16817182039&Tpk=rosewill%20600%20watt), I made sure I plugged in the necessary parts of the motherboard that needs energy correctly. I also made sure that my sata HDD and SATA DVD-Rom disk are powered up and connected to the motherboard via a SATA Cable.
Even after taking all the precautions, the monitor does not receive a signal from the motherboard. My computer case also doesn't beep, even though I am fairly sure I plugged in the necessary front cables correctly My computer case is http://www.newegg.com/Product/Product.aspx?Item=N82E16811147023.
If someone could please help me please! I have been experiencing this problem for too long and I would really want my PC up and running soon!
