Solved
Problem with primary partition
i deleted my primary partition accidentally while installing windows xp.my notebook is not booting.when i try to install windows xp again there is a problem in loading file:hal.dll.when i tried to install win 7 the allocated space for primary partition is nil.will installing win 7 fix my problem?
1 answer Last reply Best Answer
More about problem primary partition
  1. Best answer
    Installing Windows 7 should fix your issue, but here is a good XP hal.dll repair guide that has helped me out a few times: http://pcsupport.about.com/od/findbyerrormessage/a/missinghaldll.htm
Hard Drives Windows XP Partition Storage Laptops Windows 7
