Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Sound Cards > Rear surround sound speakers not playing
Forum CPU & Components : Sound Cards Rear surround sound speakers not playing
I have logitech G51 5.1 speakers and a IDT 92HD73C1 Audio card. I do not get sound from my rear speakers when I plug in all ports for speakers, but when i plug in the jack for the rear speakers into another spot they work so i know it isn't the speakers. My card is a 6-channel so i don't know why it has a problem using the mic port for speakers. even when i plug the jack into the mic port it gives me an option to use it as rear speakers or a mic, but after selecting rear speakers no sound is played. Any help would be very much appreciated.
Reply to ajrskyline
also i have enabled 5.1 surround sound but when i do the speaker test no sound comes from the rear speakers. all the others work fine.
Reply to ajrskyline
Have you tried watching a movie that is in surround sound. The rear and center speaker will not have sound if you are listening to a 2 channel audio source. Now some soundcards and onboard sound chips have the ability to output sound to all speakers from a 2 channel source usually called speaker fill.
Reply to SAAIELLO
They should still play when i do the speaker test though i can't understand it.
Reply to ajrskyline
ajr, did you ever find out the answer? i am having the exact same problem, all work, except rear, and same thing, i tested the rear speakers on a different output, and they work fine. -Sean
Reply to audioorlando
There are 2366 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Which Prog. is telling wrong CPU temp.
By Raidur, 3 hours ago:
What happens under load?
Best offers
Top experts
