My computer is freezing randomly. Temp doesn't go above 50 celsius. My computer is a custom from Ibuypower. Symptoms have arisen in past two weeks, computer if 4 months old. I run Spybot and keep the system unclogged.
Windows 7
AMD Phenom II x4 955
Asus M4A78T-D AMD 790GX
Corsair 650w
Powercolor HD5570 1GB Video Card
500GB Sata-2 WD5000ks
[core i7-DDR3] 2GB DDR3 - 1600 GAMING SINGLE, two of them
30" Dell monitor.
The problem is happening randomly. I had one online video going and opened up Windows control panel and it froze. Sometimes when I'm multitabling online poker. I can't run Prime95 stess test without a crash. Crashed while running Spybot.
-I've reinstalled the latest ATI and Adobe drivers.
-System runs on highperformance setting
- CPU? Motherboard? Vid Card? Power supply? Any way to test?
Here is the Ram info if wanted. Please help if you can. I work off my computer and lose money whenever it crashes. Thank you very much.
Type: DDR3
Channelsual
dcmode:unganged
nbfreq:2006.9
dramfreq:668.9mhz
fsbram3:10
cas#latency:9clocks
ras#tocas#delay:9clocks
ras#precharge:9clocks
cycletime:24clocks
bankcycletime:33clocks
commandrate:1T
Windows 7
Corsair 650w
30" Dell monitor.
Type: DDR3
Channelsual
dcmode:unganged
nbfreq:2006.9
dramfreq:668.9mhz
fsbram3:10
cas#latency:9clocks
cycletime:24clocks
commandrate:1T
