Please help me figure out if my power supply and MB are compatible
I decided to upgrade my Dell Studio 540s to make it a gaming PC.
I bought Antec Nine Hundred 2 to fit my monster EVGA 260 GTX nVidia GeForce card.
Also I about Thermaltake, Black Widow, PS (850W) to feed the system.
For some reason, my new PS (Thermaltake) couldn't turn my MB up. The CPUs fan runs smoothly, which means there is power going into the MB. As usual, I troubleshooted the problem .. and here are the results:
I used dell's power supply to feed the system and the computer turned ON and worked smoothly with no problems. I switched to the TT PS and fans working, but the hard disk, and the graphics card aren't working.
I used Dell's PS to run the computer, and TT to supply power to my graphics card. The whole computer is running, and the graphics card is powered up but no picture on my screen.
I am not sure if TT PS's 24-bin connector is defected .. I am just assuming based on my troubleshooting.
Maybe the power supply isn't compatible?!
Motherboard Master
Power supply Expert
Welcome to Tom's Forums! :)
Bad PSU, there'e no 'special' wiring or compatibility needed with a standard ATX PSU. Assuming an OC Core 2 Extreme Quad Core and GTX 260 a 650W is sufficient.
I would recommend that you exchange the Thermaltake PSU and get a Corsair or new Thermaltake.
Related ressources
Motherboard Authority
Power supply Master
It's a possibility, in any case it doesn't work and is a pretty low quality unit, your best bet would be to replace it.
Power supply Master
Too funny
As I said "one example"
A couple of years back Enermax and EVGA had a similar issue, Corsairs TX 950 and 650 also had issue's with certain systems, replacing the TX650 with an Antec 650 fixed it.
Motherboard Master
Power supply Expert
I remember the links well - it only showed that some Corsair PSUs were sub-manufactured, Corsair labeled, but were still very good. In contrast to the Antec bad PSUs.
Ask the community
