Need Help Building New System (only some parts needed)
APPROXIMATE PURCHASE DATE: now BUDGET RANGE: 300-400
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: gaming/movies
PARTS NOT REQUIRED: ONLY NEED PSU/RAM/GPU/CPU/MOBO
PREFERRED WEBSITE(S) FOR PARTS: newegg/amazon/anything COUNTRY OF ORIGIN: USA
OVERCLOCKING: Maybe SLI OR CROSSFIRE: Maybe
MONITOR RESOLUTION: 1920x1080
ADDITIONAL COMMENTS: I have a case, HD, CD drive, keyboard, mouse, and monitor all ready. I plan to play games on my 32 inch 1080 hdtv. Any suggestions on parts would be really helpful! I plan to upgrade in the future when I have spare money.
3 answers Last reply
More about need building system only parts needed
  1. Here is a config...but it comes to around $442($417 Including Mail-In-Rebates) though...
    X3 440 + Biostar 790GX ATX AM3
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.359497
    XFX HD 5770 + OCZ 500W
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.365771
    A-DATA 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820211364
    Except the video card, all the other components have Free Shipping...
  2. So I decided to up the budget a little bit, 400-500 range
    Can you tell me which one of these would be a better deal and if the parts are all compatible?
    OR
    MANY THANKS
  3. ^ Both are good...but I would prefer the MSI board over the ASRock...Not that ASRock is bad, but the MSI is little better in quality...
    So I would suggest you get the one that is cheaper...IF they both come down to same price or very close, then get the X4 635 config...
New Build Systems Product
