Solved
Would I need a sound card to add a subwoofer?
Here's my problem, my cousin plans to look for a 2.1 sound system during Black Friday, but his mobo only has line in, stereo, and a headphone jack and I'm wondering is there any way to add a woofer to that system as is. Here's his system, if I need a soundcard I'd like a PCI-E x1 model.
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_task=prodinfoCategory&lc=en&dlc=es&cc=pe&product=4120510&lang=es
2 answers Last reply Best Answer
More about would sound card subwoofer
  1. Best answer
    you don't need a sound card, unless you want one
    you simply run an audio line out (the green port) to the sub. the sub then runs a line to each speaker. All the wires will come with a new 2.1 system.
  2. Best answer selected by mister g.
Sound Cards PCI Express Components
