Sign-in / Sign-up
HypertTransport Link speed and PCIe Speed are set to 0.00mhz
  • AMD
  • Overdrive
  • Overclocking
February 22, 2013 5:13:55 PM
Hello,
friends!
I'm using AMD OverDrive to see my clock/voltage stats and it appears that my HypertTransport Link speed and PCIe Speed are set to 0.00mhz
I have a AMD A8-3520M APU with Radeon HD 6620g
thanks for the help!
More about : hyperttransport link speed pcie speed set 00mhz
a c 128 K Overclocking
February 23, 2013 8:20:54 AM
Hi,
If your PCI-E and HT speed really were 0Mhz the your PC wouldn't boot.
Either AMD Overdrive isn't reading the values correctly or the value (0.00Mhz) is the increase/decrease from the default value.
If you want to see your clock/voltages then use the BIOS.
m
l
February 23, 2013 2:17:24 PM
I think you right from it being from the default value.
What the best way to change these settings from the BIOS?
When I go into the BIOS I can't seen where I could make these changes, what is it under?
Thanks again!
In red it shows the current vaule, however the blue shows the target vaule. Maybe I should contact amd, or hp?
m
l
February 23, 2013 3:04:22 PM
As you have a laptop/notebook you may not have access to these settings in the BIOS , why do you want to change them anyway?
So in overdrive is your current values for PCI-E and HT 0.00Mhz, and what are the target values?
m
l
July 16, 2014 6:44:09 AM
Rustyy117 said:
Hi,
For me pcie speed is 0.00. Should I change it? Why and how? I'm facing heating issues, will changing pcie speed help?
m
l
