Been away from hardware for quite some time and would like some input from those of you that have kept up with it. (I'm glad Tom's is still going strong)
Purpose: World of Warcraft and any expansions for the next 3-4'ish years. This might be asking too much for longevity, but I'm hoping to build a higher horsepower system now that will run everything fine now w/o O.C'ing it until years later with some RAM Possible future CPU expansion availability.
OS: Win7 (unsure of which flavor yet)
CPU: i7-930 2.8 ghz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115225&cm_re=i7-930-_-19-115-225-_-Product
MOBO: Asus P6X589
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131614
Fan/Heatsink:Thermaltake Frio (no overclocking for now)
http://www.newegg.com/Product/Product.aspx?Item=N82E16835106150
RAM: Corsair DDR3 6GB 1600mhz 3ch.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233085
Drive(s): Corsair P256 SSD Sata II (ouch, is this worth $/speed wise?)
Not sure if I need a back-up HDD as I have a 1tb usb drive, but it's slow so?
Western Digital (Black) 1tbyte SATA 6.0/GB/s
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533
Video Card: Sapphire 1002805 Radeon HD-5970 (noticed out of stock)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102887
Case: Antec 1200 (cheaper is fine, I care about cooling not LED's)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129043
PSU: Antec 750w Earthwatt
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371026
DVD-R: Sony Optiarc I would put the game on the SDD/HDD so just for installing and occasional burning.
http://www.newegg.com/Product/Product.aspx?Item=N82E16827118030
Same Monitor: Phillips/Magnavox HD-TV 32" diag
1024/768 typically 1280/768 max has HDMI 1080i hookup as well as VGA
If I had of set a budget, it's already over it. The SSD drive is price is the unexpected difference, but appears that for OS and games it makes a huge difference is that the case? I probably won't do a "full" rebuild for another 10 years, so I'm looking for longevity, although I realize games epitomize hardware obsolescence.
Keyboard/mouse whatever works (keyboard faster than mouse for WOW?). I've not played WOW yet due to old hardware but have been eying it for years. It looks like Zork I but with graphics. That's an old game when modems were cradles for a telephone handset . . . have I dated myself.
No OClocking for now, although the H2O systems look amazing, I have enough hobbies.
TIA for any suggestions, corrections, advice,
Mark
CPU: i7-930 2.8 ghz
MOBO: Asus P6X589
Mark
