Hey fellas,
I have a mATX case and I have some questions for bettering my airflow. The case is a Sony VAIO OEM (RC-210G) and I have EAH5770s in CF setup. My CPU is cooled by Corsair H50 so there is not much of a problem there. At this time, at idle my temps are;
CPU: 37C
NB: 52C
SB: 44C
MB: 35C
Ambient: 26C
Both GPUs: 42C
I have an OEM Delta Fan that is on top of the case as an exhaust fan, I have an Antec and the Corsairs CPU fan used as a push pull method on the H50 radiator, one Antec spot cool near the NB, and another spot cool pointed in between the GPUs. As you see it is kind of a noise-maker.
I'd like to get this new Silverstone AP121 fan and replace all 3 120mms I have in the case. First question, Corsair's CPU fan, like any other CPU fan has a 4-pin connector (not the one that comes from PSU, the one that you plug to the MB), and case fans has 3 pin connectors, so can I plug in a 3 pin case fan to the CPU fan slot on the MB that has 4 prongs?
If I reversed the exhaust fan on top and pulled cool air in from the top onto components instead of purging out hot air, would that bring temps further down? I guess I can try it out and see but I am just trying to get the dynamics of cooling down...
There is actually not a place that you can place an exhaust fan so I cut a nice hole on top with my hole saw, cool air comes in from the H50 push pull fans at the rear in the image below;
And hot air is sucked out from the top. There is an open grill in the space in this image, but can place a fan there.
Thanks for the help...
CPU: 37C
NB: 52C
SB: 44C
MB: 35C
Ambient: 26C
Both GPUs: 42C
