Hi all,
Require advice on new card for card, really want to pop my cherry with water cooling but the GTX 480 is out next week and as a keen overclocker, full water cooling kit is a must at some stage, at the moment i have a sheepish H50 DIY kit as follows,
QX6850 @ 3.33Ghz (H50 Water Cooler)
GTX 260 @ 690Mhz Core / 1174 mem
4GBDDR2@ 1066Mhz
Corsair TX850watt
Budget: £500 budget
Preferd online retailer: ebuyer / scan / overclockers
Prefered Manufacture: Any
Deadline: 27th March 2010
Direct X 11 Option 1) GTX 480
Silent OC'd Option 2) A>New Case maybe Coolmaster CM 690 II,
B>2nd GTX 260
C>CPU/GPU Water Cooling Kit
Any comments would be most helpful.
4GBDDR2@ 1066Mhz
Corsair TX850watt
Budget: £500 budget
B>2nd GTX 260
