Help with my build please
I have purchased these parts for a new system build that I will be using mainly for a HTPC, but I wil also be doing some movie encoding as well. This is my 1st system build and Im trying to make sure I dont run into any compatibility issues. Also I've read a few reviews about antec power supply's not being fully compatible with some mobo's, somehow creating a buzzing sound........not totally sure if its the users mistake though.
1.Can I use my PSU's 20+4 pin connector together to power up the board which has a 24 pin connection? Which I know it seems like a redundant question to ask, but this is my 1st build and I dont want to fry anything....forgive me for being overcautious.
2.I also researched wiki and saw that AM2 socket CPU's will fit into an AM3 board also...can anyone confirm this??
I was given a CPU - AMD Athlon X2 64 5000 2.6 GHz True-Dual Core Design, 65w energy efficient 1MB Total L2 Cache.
which is why I chose the mobo and memory.....trying to save a few bucks.
3.Where/how am I fitting the 5 case fans power connectors? it looks like I can daisy-chain them but again, this is my 1st build.
I ordered the mobo, and memory yesterday....should be here by thursday, and I would like to get a heads up on any potential problems. All specifics of each component is listed below:
Tower: Antec 1200
MOBO: GIGABYTE GA-MA790GPT-UD3H AM3 AMD 790GX HDMI ATX AMD Motherboard - http://www.newegg.com/Product/Product.aspx?Item=N82E16813128398
Model
Brand GIGABYTE
Model GA-MA790GPT-UD3H
Supported CPU
CPU Socket Type AM3
CPU Type Phenom II / Athlon II / Sempron 100 Series
FSB 2600MHz Hyper Transport (5200 MT/s)
Chipsets
North Bridge AMD 790GX
South Bridge AMD SB750
Memory
Number of Memory Slots 4×240pin
Memory Standard DDR3 1666(O.C.)/1333/1066
Maximum Memory Supported 16GB
Channel Supported Dual Channel
Expansion Slots
PCI Express 2.0 x16 2, running at x16 or x8/x8
PCI Express x1 3
PCI Slots 2
Storage Devices
PATA 1 x ATA133 2 Dev. Max
SATA 3Gb/s 6
SATA RAID 0/1/5/10/JBOD
Onboard Video
Onboard Video Chipset ATI Radeon HD 3300 Graphics
128MB DDR3 SidePort memory
Onboard Audio
Audio Chipset Realtek ALC889A
Audio Channels 8 Channels
Onboard LAN
LAN Chipset Realtek 8111C
Max LAN Speed 10/100/1000Mbps
Rear Panel Ports
PS/2 1
Video Ports D-Sub + DVI
HDMI 1 x HDMI
USB 1.1/2.0 6 x USB 2.0
IEEE 1394 1 x IEEE 1394a
S/PDIF Out 1 x Optical
Audio Ports 6 Ports
Onboard USB
Onboard USB 6 x USB 2.0
Onboard 1394
Onboard 1394 2x 1394a
Physical Spec
Form Factor ATX
Power Pin 24 Pin
Features
Features Ultra Durable 3 Classic Technology with copper cooled quality for lower working temperature
2 PCI-E 2.0 x16 interface with ATI CrossFireX/ Hybrid CrossFireX support for ultimate graphics performance
100% 50,000 hours lifespan of Japanese solid capacitors design
Memory: G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Dual Channel Kit Desktop Memory Model F3-10666CL8D-4GBHK - http://www.newegg.com/Product/Product.aspx?Item=N82E16820231189
Model
Brand G.SKILL
Type 240-Pin DDR3 SDRAM
Tech Spec
Capacity 4GB (2 x 2GB)
Speed DDR3 1333 (PC3 10666)
Cas Latency 8
Timing 8-8-8-21
Voltage 1.5V
ECC No
Buffered/Registered Unbuffered
Multi-channel Kit Dual Channel Kit
Heat Spreader Yes
Features Compatible with Dual Channel Intel Core i5 CPU for P55 chipset motherboard, Dual Channel Core i7 CPU for P55 chipset motherboard, and AMD AM3 Platform.
Recommend Use High Performance or Gaming Memory
PSU: Antec TruePower New TP-750 Blue 750W Continuous Power ATX12V V2.3 / EPS12V V2.91 SLI Certified CrossFire Ready 80 PLUS BRONZE Certified Active PFC "compatible with Core i7/Core i5" Power Supply - http://www.newegg.com/Product/Product.aspx?Item=N82E16817371022
Model
Brand Antec
Model TP-750 Blue
Series TruePower New
Spec
Type ATX12V V2.3 / EPS12V V2.91
Maximum Power 750W Continuous Power
Fans 1, PWM (Pulse Width Modulation)
PFC Active
Main Connector 20+4Pin
+12V Rails 4
PCI-Express Connector 2 x 6-Pin, 2 x 6+2-Pin
SATA Power Connector 9
SLI Certified
CrossFire Ready
Energy-Efficient 80 PLUS BRONZE Certified
Input Voltage 100 - 240 V
Input Frequency Range 47 - 63 Hz
Output +3.3V@25A,+5V@25A,+12V1@25A,+12V2@25A,+12V3@25A, +12V4@25A,-12V@0.8A,+5VSB@3.0A
Approvals UL, CUL, CE, CB, FCC Class B, TUV, CCC, C-tick, BSMI
Features
Connectors 1 x Main connector (20+4Pin)
1 x 4-Pin ATX 12V
1 x 8-Pin EPS 12V
9 x Peripheral
9 x SATA
1 x Floppy
4 x PCI-E
Features Compatible with Core i7
Highest quality Japanese fan and capacitors ensure long-term reliability
DC to DC voltage regulator modules for greater system stability
Blue internal LED illumination
120mm PWM fan runs up to 50% quieter than standard fans
Advanced Hybrid Cable Management improves airflow and reduces clutter
Double layer PCB optimizes cooling efficiency and allows for heavy duty components
Universal Input and Active Power Factor Correction
Supports dual GPUs and dual/quad core CPUs
Industrial grade protection
2 answers Last reply
More about help build please
  1. no am2 cannot work in am3 boards but am3 can work in am2 and am2+ sockets
    rather grab this power supply its specially made for the big antec cases and 850 watts thats cheaper
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817371024
  2. You need an AM3 CPU for that AM3 board, don't try that CPU. You won't have any problem with thaT PSU.
Build Systems Product
