Hi
I have a cooling issue. I had an intel stock cooler which was giving temp as 42 degrees, I decided to replace it with the arctic freezer 7 pro.
The temp still stays at 42 degrees. and on use it climbes to a max of 56 degrees. I thought it was the paste whic I replaced with my own.
The strangest thing is Windows is reporting the temp different from bios.
The free sys tool from piriform measures the cores temp seperatly and works out the average temp. The temp it worked was 37 degrees but bios showed difference
My specs
Asus P5KSE/EPU Mainboard
Windows 7 Ultimate
2 GB Dual Channel DDR2 667 RAM
500 GB WD500 Western Digital Sata HDD
LG DVD Writer Non lightscribe
Arctic cooler 7 Heatsink
E3300 Celeron Dual Core CPU
Isonic 789 Case with side panel
400 Watt PSU
9400 GT Nvidia Graphics PCI Express
I wanted the bios to read 28 degrees on idle if possible, what Iam I doing wrong? I cannot understand why the temp
My specs
Windows 7 Ultimate
400 Watt PSU
