I got this board BIOSTAR TForce TA790GX A3+ AM3 AMD 790GX HDMI ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138141
I have a 5770 in the main pci-e slot and i'd like to keep the pci e slot open incase crossfire somewhere down the line.
I bought a usb wireless adapter at walmart they didn't have any pci slot ones so this was the only option, its alright but it looses connection pretty often because of where i have to plug it in at my girlfriends leg ends up bumping it and lose connection pretty often... i was wondering what would be a decent built in wifi card that i could put on this motherboard.
newegg says it has
Expansion Slots
PCI Express 2.0 x16
2 x PCI Express 2.0 x16 (single x16 or dual x8)
PCI Express x1
PCI Slots
so im really trying to figure out what card would be comptabile heres one im looking at.. btw i use wireless g and eventually possibly n but not really that big of a deal if it doesn't do n and this is a win 7 64bit cpu im running it on.
i'm looking for something under the 30 dollar range..
I dont use wep which i know is probably stupid but ya I don't really want to slow down my wireless by encrypting it.. so maybe that makes this cheaper? lol
http://www.newegg.com/Product/Product.aspx?Item=N82E16839121008
http://www.newegg.com/Product/Product.aspx?Item=N82E16833166011
sorry for bothering with such a dumb question
Thanks, Cole
newegg says it has
Expansion Slots
PCI Express 2.0 x16
PCI Express x1
PCI Slots
Thanks, Cole
