hotshizzle
54
Hi, I have gotten all of my components setted all up for the past 2 days and made sure everything is right. The cables are everywhere but its manageable. I don't get whats the problem why the computer doesn't turn on. When I plug in the PSU and turn it on the case fans and the video card fan starts. So I'm sure the mobo isn't broken. However when I press the power on button on the case it doesn't do anything I think I connected the power leds and stuff wrong. The thing is I don't know what I should do now..
^ So you are saying that the power LED doesnt work but the PC works right ?
Did you check the mobo manual ? It should contain the diagram of the layout and also would tell where to connect the LED wires...
And by the way which mobo do you have ?
