Hi everybody
I think the title just about says it all. I have a laptop cooler pad powered via USB; I can hear a very annoying, not too loud humming sound in my headphones. If I disconnect the cooler the buzz goes.
I have an Asus m50sa laptop running XP SP3. IIRC back when I had win7 installed i could disable the mic or something and make the problem go away but there's no such features in XP.
Don't bother with muting the mic and such I tried it. Also turning the system volume up/down doesn't make any difference. I tried to disable Realtek High Definition Audio from Device Manager and enabling it again brought just a few seconds of silence then again: buzzzzzzzzz.....
I would very much like a registry tweak to disable the mic and stereo mix.
Thanks guys
Thanks guys
