I'm doing these voltages using asus probe II and I'm going by the lowest voltage i seen and the highest
idle
3.3v 3.22-3.25
5v 4.91-4.97
12v 11.97-12.03 kinda stayes at 12.03
running crystaldiscmark,furmark all max out,prime 95 using max power consumption.
5min
3.3v 3.18-3.26
5v 4.86-5.02
12v 11.73-11.97 kinda stays at 11.85
i have this graphics card(ATI 4770) for 1 mouth now and it did this 2 times in a 8 day radius...all i did is restart my pc and the card did not show anything it even loaded into windows 7 without the card working i heard the windows 7 sound and then i turn it off,i keep turning my pc on and off until i get it to work. so do i need a new power supply?
the fan on the card keeps spenning for about 10sec and then it stops when it messed up(on just a restart)
i play games all the time and nouthing ever happens(COD5,GTA4)so on
heres the rest of my system
amd athlon x4 620 OC 3.25ghz
3GB of ram
320GB hard drive
ATI 4770
Antec earthwatts 380watt
antec 300 case
3 120mm fans
1 140mm fan
asus m4a785-m
please help if you can
idle
3.3v 3.22-3.25
5v 4.91-4.97
5min
3.3v 3.18-3.26
5v 4.86-5.02
3GB of ram
320GB hard drive
ATI 4770
antec 300 case
3 120mm fans
1 140mm fan
asus m4a785-m
