Help deciding on Case please!
Basically, I need help deciding whether I should get this case:
COOLER MASTER HAF 922 RC-922M-KKN1-GP Black Steel + Plastic and Mesh Bezel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119197
or this case:
Rosewill CHALLENGER Black Gaming ATX Mid Tower Computer Case ,comes with Three Fans-1x Front Blue LED 120mm Fan, 1x Top 140mm Fan, 1x Rear 120mm Fan, option Fans-2x Side 120mm Fan
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153&nm_mc=EMC-IGNEFL061810&cm_mmc=EMC-IGNEFL061810-_-EMC-061810-Index-_-ComputerCases-_-11147153-L01B
I know everyone loves the HAF 922 but the Challenger seems almost exactly the same but a bit smaller and is $55 cheaper with the promo code. The smaller size will help when I have to lug it to my dorm in a couple of months...
Oh and this will probably be my power supply
XION Supernova XON-800R14N 800W ATX12V / EPS12V SLI Certified CrossFire Ready Modular Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817190016
Will that go well with the case? People have had problems with it being bottom mounted though...
9 answers Last reply
More about help deciding case please
  1. You really need to tell us whats going to be in this case.
    are you o.c.ing and need extra cooling?
    etc.....
  2. It depends on what you want to put in it, the larger size of the HAF 922 will let you fit larger graphics cards in there and will give you significantly better cooling with its larger fans than the challenger. But if you are building a fairly low power system and using a moderately sized graphics card you dont need the extra space and cooling that the HAF offers.
    Psycho you realize that the CPX PSUs can only be used in a few Antec cases right like the 1200, P180, and P193? I agree that his old PSU choice isnt good but yours cant fit. I suggest getting a quality unit, the 550VX if you are only planning on running a single card, or the TP-750 if you plan on running CF or SLI down the line.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139004&Tpk=550vx
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817371025&cm_re=TP-750-_-17-371-025-_-Product
  3. ^^ I might OC ini the future, but I just want a case that has enough airflow but isn't huge and doesn't cost that much. Basically I'm asking if the Challenger will give me any problems, or will it benefit be greatly to go with the HAF 922?
    ^ The power supply is suitable for my budget. Though I might have to put it in upside-down because the fan's apparently on the bottom..
    Build is basically this with a few modifications to power supply and HDD and stuff. Planning on getting another GPU for crossfire in the future though
    CASE: Cooler Master HAF
    http://www.newegg.com/Product/Prod [...] 6811119197
    CPU: AMD Phenom II x4 965
    http://www.newegg.com/Product/Prod [...] 6819103727
    GPU: Powercolor AMD Radeon HD 5770
    http://www.newegg.com/Product/Prod [...] 6814131330
    RAM: OCZ Platinum 4gb (2x4gb)
    http://www.newegg.com/Product/Prod [...] 6820227478
    HDD: SAMSUNG Spinpoint F3 1TB
    http://www.newegg.com/Product/Prod [...] 6822152185
    PCU: APEVIA ATX-JV 650W
    http://www.newegg.com/Product/Prod [...] 6817148041
    Cooler: Scythe SCMG-2100 Sleeve CPU cooler
    http://www.newegg.com/Product/Prod [...] 6835185142
  4. Hm that 750W one looks pretty solid.. What's wrong with mine though?
  5. Alrighty then, antec it is
  6. Still unsure about the case though.
  7. How good is the airflow with the destroyer?
  8. I like these 2 cases:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811129066&cm_re=antec_three_hundred-_-11-129-066-_-Product
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042&cm_re=antec_three_hundred-_-11-129-042-_-Product
    Difference is the Illusion has more fans with LED's on them, both have been used by tons of people and Tom's SBM's for quite a while.
  9. Out of the original 2 cases I think the Rosewill's more suited to you, but the Antec 300 Illusion's a good alternative that also has a bit more cooling.
Power Supplies Cases Fan Components Product
