Hi All,
So I have read the Water Cooling Sticky and I think I have this water cooling stuff figured out. (I think). My current setup is all air and it sucks bc its hot and loud and I want to push the clocks so here I am ready for water...
Parts are as follows:
MB: RIVE
CPU: 3930k
MEM: 16gb GSkill
GPUs: 4 x MSI 7970
PSU: 1600w Lepa
CASE: CaseLabs Magnum STH10
GPU BLOCKS: 4 x EK Nickel / Acetal CSQ using quad bridge,
CPU BLOCK: EK Nickel / Acetal CSQ
MB BLOCKS: Cant decide.
RADS: 2 x 480 GTX BlackIce Xtreme and 2 x 360 Alphacool UT60
FANS: Corsair SP120 High Performance x 32 (2350 rpm)
RES: BitsPower Z Multi 250 Inline
PUMPS: Swiftech Dual Extreme Duty Small Form Factor 12 VDC Industrial PWM Pump - Black (MCP35X2-BK)
TUBING: 1/2 by 3/4 PrimoChill
FITTINGS: BitsPower Compression
I figure my TDP to be about 1400 (300 per gpu and 200 cpu). Total Rad space is 1680 leaving me a little something, something left over.
Questions:
1. Is my Rad space sufficient? (From what I know I should be gtg)
2. Is my pump sufficient or should I add another?
3. I am debating on cooling my MB. Is it worth it? (I understand it can help with OC the CPU) If I add blocks to my RIVE will I need to add another RAD or PUMP to help with restriction?
Thanks all for your time and expertise.
MB: RIVE
CPU: 3930k
MEM: 16gb GSkill
GPUs: 4 x MSI 7970
PSU: 1600w Lepa
Questions:
