Hi guys,
i was trying to install windows 7 ( was going to format my hd ), its all sorted now but at one point i had reset my computer (this was before trying to install w7) and i had lots of green and other coloured lines going through my screen, i tried to reset it a couple more times and now when ever i have the monitor attached to my gt 240 the screen is so dark you cannot see anything, alot of the images are disorientated and fuzzy, the screen seems to be a very dark bluey/purple colour, i plugged my monitor into the on board video display on my motherboard and NOTHING came up at all, i then removed my GT 240 and then tryed and the image is working perfectly, i have NO idea what is wrong, i recently ordered a ati 3870x2 which should be here tomo but after having a little think, im guessing my vga port on my graphics card might of died because i do not use DVI.., i will recieve a dvi connector tomo with my new graphics card so i will let you guys know if thats the problem, other than that i cannot think of anything else, if any of you might know whats up please do say, im willing to try everything. Thanks again.
