Help with Front Panel Wiring (pictures included) ??
Last response: in Systems
April 10, 2010 1:12:20 PM
Please help me with the wiring .....i finish building all the pc but the wiring is confusing.... i manage to put most of them but there is two thing :
1-power LED (there is't any place for it even in the back)
2- the HDD LED (should i flip the (+) and the(-) sides)
the pictures are included
http://img260.imageshack.us/i/img003211.jpg/
http://img686.imageshack.us/i/img003422.jpg/
a b B Homebuilt system
April 10, 2010 1:16:49 PM
Yes flip HDD led, red wire is +.
And I'll have to check my case but why would they make the power led on the mobo a 3 pin connector but 2 pin on the case.
If you don't have a spare/old 3-pin connector housing then simply push out the pins and connect it that way to the female pins. Use an X-facto knife to push down the retainers carefully.
m
l
April 10, 2010 3:02:06 PM
Yes, flip the HDD LED...
Your POWER LED should plug into the PLED slot on the second picture. Your internal case speaker is installed in the other four slots. Another option, is to plug them directly into the MOBO and not use the adpator to see if everything fits. I have never used that adaptor for any of my builds.
m
l
