System build for less than 1500
Last response: in Systems
APPROXIMATE PURCHASE DATE: 1 to 2 week
BUDGET RANGE: less than 1500 before tax
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: +++Gaming, surfing, movies
PARTS NOT REQUIRED: Mouse, keyboard, monitor (depend on the price)
PREFERRED WEBSITE(S) FOR PARTS: ncix, newegg, directcanada
COUNTRY OF ORIGIN: Canada
PARTS PREFERENCES: RAM (Corsair), doesn't really mather
OVERCLOCKING: Yes
CROSSFIRE: Maybe
MONITOR RESOLUTION: 1920x1080+
ADDITIONAL COMMENTS: I also need windows (XP SP3 or 7??). Water cooling (corsair H50) for the CPU or Fan?
He is what I found:
ASUS Radeon HD 5770 1GB DDR5 PCI-E VGA DVI-I HDMI Video Card (Twice)
Corsair XMS3 TW3X4G1333C9 4GB DDR3 2X2GB DDR3-1333 CL 9-9-9-24 Dual Channel Memory Kit
Western Digital WD WD10EALS Caviar Blue 1TB SATA 3GB/S 7200RPM 32MB Cache 3.5IN Hard Drive OEM (500 gb and 1TB should be good)
Coolit Systems Eco CPU Water Cooling System AUTO-REGULATED & Maintenance Free LGA1366/1156/775/AM3
http://www.ncix.com/products/index.php?sku=50327
Intel Core i5 750 Quad Core Processor Lynnfield LGA1156 2.66GHZ 8MB Cache Retail Box
http://www.ncix.com/products/index.php?sku=42499
Coolermaster Haf 922 Mid Tower ATX Case Black 5X5.25 5X3.5INT Front Audio USB eSATA No PSU
http://www.ncix.com/products/index.php?sku=38996
Gigabyte P55A-UD3 ATX LGA1156 P55 DDR3 2PCI-E 2PCI RAID GBLAN CrossFireX USB3.0 SATA3 Motherboard
http://www.ncix.com/products/index.php?sku=46237
ASUS PCI-G31 Wireless Network Adapter 802.11G 54MBPS PCI
http://www.ncix.com/products/index.php?sku=43639
Corsair TX750W 750W ATX 12V 60A 24PIN ATX Power Supply Active PFC 140MM Fan
http://www.ncix.com/products/index.php?sku=26415&promoi...
Microsoft Windows 7 Home Premium Edition 64BIT DVD OEM
http://www.ncix.com/products/index.php?sku=45271
Liteon IHOS104 4X BLU-RAY Reader BD-ROM Drive SATA Black Retail Box
http://www.ncix.com/products/index.php?sku=48084
That's what I found for my build. If you have any comments or suggestions I'm very open (don't mind changing for AMD, Nvidia, etc, I just want a good build performance/build for gaming).
Do you think that this motherboard would handle well Crossfire?
Thanks.
OVERCLOCKING: Yes
CROSSFIRE: Maybe
He is what I found:
Thanks.
More about : system build 1500
Couple of Recommendations:
HDD: Samsung Spinpoint F3 1TB - One of the fastest non-SSD hard drives you can purchase.
HSF: Cooler Master Hyper 212 Plus - Stick with Air unless you plan on 4.3 GHz plus overclocks on a 24/7 system... IMO
RAM: G.SKILL Ripjaws 4GB (2X2GB) DDR3-1600 - Same price with tighter timings...
Go with Windows 7 for all new builds... IMO!!
You can drop your power supply down to the Corsair TX650 and still have plenty of power for your system.
Your motherboard isn't good for a Crossfire setup (16x,4x). You want a motherboard with at least a 8x,8x setup for Crossfire.
Related ressources
- ATI 5970 and Phenom ii x4 965 Build -- Less than $ 1500 - Forum
- Less than $ 1500 solid gaming build - Forum
- game system for less than 1500 .00? - Forum
- Suggestions for this build ? Budget: less than 1500 dollars - Forum
- Ground Up Gaming PC Less Than $ 1500 - Forum
tecmo34 said:
Couple of Recommendations:Go with Windows 7 for all new builds... IMO!!
+1.
To expand on that: The CoolIt,H50,etc doesn't do any/much better than many of the "Big" air coolers (ie TRUE, Mega, S1283, Core Contact,212+,etc). If you want REAL water cooling, it will cost you ~$250 (USD) easily.
Imo, for a gaming build, I'd personally go with an AM3 sand save a bunch of money. An Athlon X3/X4 can be had quite cheap.
One more thing: If you plan to play games at 1920x1080, you probably want to get a 5850/5870 or so.
Best solution
I agree on going with the Hyper 212 air cooler unless you really want to get nuts on OCing
Ripjaws, good buy.
The Gigabyte P55 board you listed is a good board. However, take note that P55 boards generally do not work well with Crossfire. Depending on the particular board, the second PCI-E x16 can be crippled by the 3.0 USB and/or SATA 6gb/s. I'm not too sure on that ASUS, but AFAIK it's an issue with all P55 boards. The Gigabyte one though definitely only runs at x4 electrical on the second PCI-E x16 in Crossfire, so that eliminates it as a realistic CF board imo.
I agree on going with a 5850 or 5870 if your purpose is gaming. There are three things to consider here:
1) Get a more expensive motherboard to ensure you can use at least x8/x8 Crossfire down the road, and get a 5850.
2) Go with a cheaper board that still has 3.0 USB and 6gbs SATA and get a 5870, with no plan to CF later.
3) Go AMD and save even more money on a Quad and Motherboard. Get a 5870, with no plan to CF later.
Options 2 and 3 allow you to save $ now and reinvest in 2-3 years, if and when you feel the 5870 isn't up to it anymore and just get a new card. Option 1 will cost you more now but allows you to just try and find a cheap 5850 down the road (but don't wait too long, already 4870's are getting harder to find at reasonable prices).
So it just depends on which way you want to flex your budget. Personally if gaming is the focus, I'd just get an AMD Quad, OC that with the Hyper 212, Get the $90 Gigabyte UD3 motherboardboard with usb 3.0 and Sata 6s, and a 5870.
Oh and you can also drop down to an Antec Earthwatts 500 or 650W PSU (whatever is on sale, usually one of the two is) if you just use the 1 vid card.
Also, not sure how often you buy from NCIX. But make sure you use the manufacturer's part # on their product pages to pricematch! Use shopbot.ca and/or pricebat.ca and search using the product #. Will give you Canadian results and you use those links to PM on NCIX's checkout page. Can save a good chunk of coin doing this
Product has to be in stock at both stores though, and any 3% cash discounts don't work for PM (gotta use the reg or sale price).
Good luck!
Ripjaws, good buy.
Product has to be in stock at both stores though, and any 3% cash discounts don't work for PM (gotta use the reg or sale price).Good luck!
So it would be cheaper to go with amd?
is this a good one?
Is it good for overclocking? (with hyper 212)
With this motherboard
GIGABYTE GA-770TA-UD3 AM3 AMD 770 SATA 6Gb/s USB 3.0 ATX AMD Motherboard - Retail
What memory should I take to go with this board? still G.Skill?
And if I want to stay with intel, any good motherboard for the i5 that can do well with Crossfire?
thank you very much.
is this a good one?
ASUS Radeon HD 5770 - I'd go with one 5850 and then move up later.
Corsair XMS3 TW3X4G1333C9 - CAS 9 is a bit slow and DDR3-133 will limit your OC potential....many CAS 7's DDR3-1600's at this price range
http://www.newegg.ca/Product/ProductList.aspx?Submit=EN...
I'd avoid the RAM modules w/ the tall heat spreaders (i.e. the dominators and some from Gskill) as they often interfere w/ HSF's. I haven't had a problem w/ the Mushkin coolers as yet but unless you doing serius OC's, ones w/o any heat spreaders will do just fine.
Hard Drives - Check out the performance charts and pick whatever 500 GB per platter drive performs best under your usage patterns. The 2 TB WD Black and XT from Seagate are good choice but at smaller capacities, you are limited to the Seagate 7200.12 or the Spinpoint F3. The 7200.12 excels in gaming, multimedia and pictures whereas the F3 wins at music and movie maker. See the comparisons here (copy past link in manually, link won't work in forum):
(http://www.tomshardware.com/charts/2009-3.5-desktop-har...[2371]=on&prod[2770]=on)
Look at the tests that reflect your usage and choose accordingly.
Coolit Systems Eco CPU Water Cooling System - Not impressed. A good air cooler will top its performance and be less headaches. For performance and ease of installation, the Prolimatech Megahalems fits both criteria.
If that's a budget breaker, look at the Xigmnatec S1283 or one of the others here:
http://www.silentpcreview.com/Recommended_Heatsinks
http://www.frostytech.com/top5heatsinks.cfm#INTELHEATSI...
http://benchmarkreviews.com/index.php?option=com_conten...
pick a TIM from the top few here:
http://www.hwreviewlabs.com/index.php?option=com_conten...
http://www.xbitlabs.com/articles/coolers/display/therma...
Gigabyte P55A-UD3 ATX LGA1156 P55 - Asus boards don't have their ESB 3 / SATA III crippled when adding a 2nd GFX card.
http://www.tomshardware.com/reviews/usb-3.0-performance...
Gigabyte’s P55A-UD4P cuts costs by using the processor’s PCIe 2.0 connections to host its high-bandwidth controllers. Two of the primary graphics card’s 16 PCIe lanes supply its USB 3.0 and SATA 6.0 Gb/s controllers, and Gigabyte disables six more lanes to make the upper slot an effective x8 interface. The USB 3.0 and SATA 6.0 Gb/s controllers revert to the chipset’s 2.5 GT/s lanes whenever two graphics cards are installed, to preserve the x8 transfers each graphics card needs for optimal CrossFire or SLI performance
Thus, users with a single graphics card must sacrifice half of its peak bandwidth to enable 5.0 Gb transfers to the USB 3.0 and SATA 6.0 Gb/s controllers, while those with two cards must live with 2.5 Gb/s bandwidth limits on USB 3.0 and SATA 6.0 Gb/s controllers. Neither of these sacrifices is huge or even noticeable on most of today’s hardware, yet anyone trying to future-proof their system could be left cold.
http://www.newegg.ca/Product/Product.aspx?Item=N82E1681...
Corsair TX750W 750W - Overclocking w/ twin GFX cards, I'd recommend a HX series from Corsair
....alternate would be a CP-850 from Antec but that would requires a case change.
I think I made my choice, I'll go for the AMD with 2 5770 (cheaper). Any other suggestions? I could have this build for around 1400+tax. Do you think that the Crossfire cards will obstruct the pci slot for the wireless adapter?
ASUS Radeon HD 5770 1GB DDR5 PCI-E VGA DVI-I HDMI Video Card *IR-$15*
AMD Phenom II X4 965 Black Edition Quad Core Processor AM3 3.4GHZ 8MB Cache 125W 45NM Retail Box
Coolermaster Hyper 212 Plus Direct Touch 4 Heatpipe Heatsink AM2 AM3 LGA1366 LGA775 LGA1156 120MM
ASUS M4A78T-E ATX 790GX Socket AM3 DDR3 2PCI-E16 2PCI-E1 2PCI HDMI Video Sound GBLAN Motherboard
Coolermaster GX 750W 80+ Power Supply SLI ATX12V V2.31 24PIN Active PFC PCI-E 120MM Fan
Seagate Barracuda 7200.12 1TB SATA2 3.5IN 8.5MS 7200RPM 32MB Hard Drive OEM *3YR MFR Warranty*
G.SKILL F3-12800CL9D-4GBNQ PC3-12800 4GB 2X2GB DDR3-1600 CL9-9-9-24 240PIN Dual Channel Memory Kit
thanks
thanks
That makes sense, would you go with any particular brand? editions?
I found it for 360 on newegg.. Do you guys thinks it would be easy to find in like a year or 2?
what about this bundle
http://www.ncix.com/products/?sku=52200&vpn=XFX%20650W%...
and use this power supply instead, would 650 be enought for 2 5850?
lots of question, sry
Yes, it has 52V on the a single 12V rail, which is strong enough for two 5850's, along with it comes with enough PCIe connectors, which most 650W PSU don't. Plus, you are getting a good combo deal with it. If you don't get the XFX, stick with the Corsair... don't get the CoolerMaster PSU (they aren't the best of PSU brands...)
Looking good with the PSU and 5850.
If you're ordering everything from NCIX, don't forget to do the pricematching
and if you live in Ontario or further out east, definitely check the shipping cost with and without the case because they can jack up shipping costs from BC (where NCIX is). Just buy the case locally from Canada Computers or something if it brings up the shipping cost too much.
Oh and also, I think the HAF comes with fans everywhere except the side. So you may or may not want to grab an extra 200mm fan for that (or 2x 120mm if I remember correctly).
Enjoy your new rig!
and if you live in Ontario or further out east, definitely check the shipping cost with and without the case because they can jack up shipping costs from BC (where NCIX is). Just buy the case locally from Canada Computers or something if it brings up the shipping cost too much.Oh and also, I think the HAF comes with fans everywhere except the side. So you may or may not want to grab an extra 200mm fan for that (or 2x 120mm if I remember correctly).
Enjoy your new rig!
w00t w00t, the guy will process my order on Monday, and apparently the shipping is free over 300$. The build is 1370 before taxes with all the pricematching (I saved almost 200$). Can't wait to build it and start it!
i built a computer 3 years ago with a friend, I should be able to do this one on my own.. I hope :S.. It'll be interesting
One more question, apparently shipping isn't free with ncix.. my bad :S
I could get the same system with a 5870 from Gigabyte
http://www.directcanada.com/products/?sku=11830BD3930&v...
Would you take the XFX 5850 black edition or the 5870?
Thanks again
Thanks again
I ordered this
Powercolor Radeon HD 5870 PCS+ 875MHZ 1GB 4.9GHZ GDDR5 2XDVI HDMI DP DIRECTX11 PCI-E Video Card
What do you think?
What do you think?
Thanks to everyone, I installed everything, from A to Z in about 2 hours + installation of Win7. Everything is working incredibly fine! love it! I just need to find the good voltage and core speed for the 965 and the 5870 and to find it in the bios lol. I'm scared to start the computer with the wrong setup and fry it.
anyway, thanks to everyone!
Related ressources:
- ForumCan you build something better than my system for less money?
- ForumLess than 1500 $ Developing Programming Database and a little Gamming
- Forum$ 1500 Noob Gaming Rig Help -- Little knowledge, less confidence
- ForumNew build 1500 or less budget
- ForumFeed Back on a $ 1500 or less gaming build please
- ForumLooking for prebuilt 1500 or less just tower.
- ForumGaming PC for $ 1500 or Less
- ForumNew to building 1500 $ limit like to spend less
- Forum$ 1500 (or less ) gaming computer
- ForumCheap expandable i7 build for less than $900
- ForumHelp Building $700 Gaming PC
- Forum[Solved] Newbie Build
- ForumPc build $600 budget
- ForumPlease review my $800 build
- ForumNew System Boot Error: Narrowed down to one stick of RAM
- More resources
(Should be 52A). And +1 for XFX, Corsair and a single 5850 (so you can CrossFire when prices drop later).
