Hey all,
So I just bought another Western Digital WD10 Black 1 TB HDD to match my existing HDD, (also the same HDD).
Keep in mind I already have Windows 7 64bit plus 500 GBs worth of data on the first HDD.
I want to set up RAID 0 with both of them.
The manual says to use Intel matrix storage manager to make the RAID configuration.
So I went to bios and set Storage Configuation from IDE to RAID.
The manual then says to access Intel Matix storage by hitting Control + I or L (tried both) during POST. That did not work. I reinstalled Intel Matix storage, and I still could not access it. Nothing happens with that combination.
However, for literally around 30 milliseconds "Intel Matix storage" followed by some text happens in post.
I then did some research online.
Intel came out with a new RAID configuration tool, Intel® Rapid Storage Technology.
I downloaded and tried installing that , and I got BSOD. I then set Storage configuration in BIOS back to IDE, tried to install it again, and it said your system does not meet the requirements.
I then did more research and it seems like it is possible to set up RAID in control panel > administration tools > Computer Management > Disk Management.
If you right click the unallocated HDD there is a grayed out option called "New Stripped Volume". However, when I format the drive, the option disappears.
So is this how to set up RAID0 with all these updates?. I was told you have to erase everything and do it during windows install? I was prepared to format both drives and do this...
System Specs:
Windows 7 64 Bit
Asus P6x58D Premium (supports ICH10R)
2 x Western Digitial WD10 Black 7200RPM 1 TB HDD's. One is formatted NTFS while the other is brand new and unallocated.
8 GB Corsair RAM
Core i7 930
2 x GTX460
bla bla bla
Thanks
System Specs:
Windows 7 64 Bit
8 GB Corsair RAM
Core i7 930
2 x GTX460
bla bla bla
Thanks
