Hard drive speed
Forum Laptops & Notebooks : General Laptops & Notebooks - Hard drive speed
Archived from groups: comp.sys.laptops (More info?)
G'day,
Does anyone have recommendations on hard drive speed?
Specifically, I can buy either:
80gb Ultra ATA Hard drive (4200rpm), or
60gb Ultra ATA 7200rpm Performance Hard drive.
The 7200RPM is AU$100 more expensive...
My question is: is the faster hard drive worth it? Is there a
noticable difference? Does it drain the battery faster (it's got a
pentium M processor)?
Cheers, Sven.
Sponsored Links
"Sven" <ohsosven@hotmail.com> wrote in message
news:1f888818.0409142029.173893a8@posting.google.com...
> G'day,
Depends on how much disk intensive work you do.
> Is there a noticable difference?
Yes.
Yes.
Reply to Anonymous
Go for the 7200 you wont regret it.
Reply to Anonymous
Done and done.
Cheers, Sven.
Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
Reply to Anonymous
Sven <ohsosven@hotmail.com> wrote:
> G'day,
Go to the datasheets, and compare idle powers.
There may be a fair difference between the two.
7200 drives will generally drain battery faster.
Reply to Anonymous
- 0 +
Sven,
If price is an issue consider these as a satisfying compromise:
USD$128 for a Toshiba MK6026GAX - 60GB ATA-6 -
9.5mm - 5400RPM - 16.3MB Buffer
http://www.zipzoomfly.com/jsp/Prod [...] ode=101671
USD$181 for a Toshiba MK8026GAX - 80GB ATA-6 -
http://www.zipzoomfly.com/jsp/Prod [...] ode=101678
I've been pleased with both for several months.
Regards ... John
Reply to john
>> G'day,
Hitachi and Toshiba both claim better idle optimization with new fluid
bearing tech for their 7200rpm notebook drives than for their lower
speed drives, resulting in equal or reduced idle power.
Q
Reply to Anonymous
Quaoar <quaoar@tenthplanet.net> wrote:
>>> G'day,
Look at the claims carefully.
Some of them are bogus, based on meaningless (for a laptop) measures,
like power per gigabyte.
(important in a server farm, with thousands of drives, irrelevant
in a laptop)
Reply to Anonymous
> 9.5mm - 5400RPM - 16.3MB Buffer"
wow 16mb buffer,,,, never knew
Reply to Anonymous
"EzAk" <crucial@execulink.com> wrote in message
news:Wsudnd4RmeMTof3cRVn-hw@golden.net...
the 16MB buffer gets them close to the 7200RPM Hitachi speeds.
Reply to Anonymous
"Thunder PC" <reply@board.nomail> wrote in message
news:2VX7d.21228$yp.16557@bignews1.bellsouth.net...
NO!
Reply to Anonymous
"Ron Reaugh" <rondashreaugh@att.net> wrote in message
news:5h_7d.480717$OB3.199320@bgtnsc05-news.ops.worldnet.att.net...
> NO!
OTOH the 50GB Toshiba MK5024GAY with
7200rpm and 16MB cache outperforms
the E7K60 Hitachi drives. I have
tested both, and the Toshiba is
the better drive -- also much
quieter.
dk
Reply to Anonymous
Nope.
Sooner or later the cache fills
up and the drive reaches steady
state.
dk
Reply to Anonymous
"Dan Koren" <dankoren@yahoo.com> wrote in message
news:41607d1d$1@news.meer.net...
| Nope.
| state.
On paprer, sure. However I have seen many many many benchmarks contrary to
your logic. The 7200RPM is definately still faster, but not by much in most
operations.
Reply to Anonymous
| NO!
Yes ... do the research. Every benchmark I have seen as well as my own
experience has shown that to be the case. The 7200RPM is still faster, but
not by a very large margin.
Reply to Anonymous
- 0 +
I'm thinking it would depend on what you're trying to do. If you're working
with a 4GB database file, that 16MB buffer will have limited effect, I would
guess. Benchmarks vs. real-world are often quite different.
Clint
news:yad8d.14975$DV3.13236@bignews5.bellsouth.net...
> | Nope.
> | state.
most
> operations.
Reply to clint
news:Ocd8d.14976$DV3.13733@bignews5.bellsouth.net...
> | NO!
So do it.
Provide a citation.
> as well as my own
No, try something that is seek intensive like a database access.
Reply to Anonymous
news:mWm8d.665057$Gx4.291656@bgtnsc04-news.ops.worldnet.att.net...
| > | NO!
| So do it.
I have.
| Provide a citation.
Google.com would be a good starting point
| > as well as my own
but
I'm not arguing that the 5400 16MB cache is the same speed as the 7200RPM.
I personally prefer the 7200RPM drives, and am well aware they are faster.
The 16MB cache drives do work to close the gap between the 5400 and 7200RPM
drives though. If you believe otherwise, you have obviously never used the
three or done the research.
Reply to Anonymous
Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > Hard drive speed
There are 993 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
