Sign-in / Sign-up
Closed
Should I connect all my case fans to a PWM slot?
  • Heatsinks
  • Cases
  • Connection
  • Motherboards
  • Overclocking
March 2, 2013 6:59:37 AM
Title says it. About to do my first build and ordered new case fans as the stock ones kinda blew (pun intended). My motherboard has 5 pwm slots (GB z77 UD3h) and I have 6 fans including the CPU cooler. Bought a pwm splitter to hook two up to the CPU pwm slot.
Anyway, just want to know of its okay to have all of my fans powered/controlled through the motherboard. Thanks
More about : connect case fans pwm slot
Best solution
a b V Motherboard
a c 128 K Overclocking
March 2, 2013 7:19:09 AM
Hi,
Short answer: Yes
In most cases the answer will be yes, it would only be no if you had really high power fans and running two of them off a motherboard header would draw too much power.
March 2, 2013 7:23:02 AM
Alright, awesome. Bought four Rosewill Hyperborea 140mm and one 120mm, so nothing too crazy. Thanks for the quick response
Score
a b V Motherboard
March 2, 2013 7:26:08 AM
Yep those fan's will be absolutely fine on your motherboard headers. ;)
Score
March 2, 2013 7:28:32 AM
Best answer selected by jibsTH.
Score
