p4nz3rm4d said:
what about the upcoming "Bulldozer" family?
Ok now that just getting annoying with bulldozer already.
Few things,
1. What if the person needing the cpu now? From what im aware of (unless something change with AMD schedule), bulldozer wont be around for another 5 to 6 months at the soonest. It maybe longer up to a year.
2. we dont have any performance or price numbers to think about a cpu with the Bulldozer arch. For all we know, AMD may take the performance lead and thus taking intel pricing scheme. Making intel have better price/performance ratio cpus (like what AMD has now).
So lets not bring up bulldozer to everything about future cpus and/or cpu buys. As most of us on here say, Get the what you need now as
there will always be something better later.
Anyways as for the original question,
Quote:
Hey guys as title says there is just 0.4 mhz difference, some say it worth some not...
1055t= 2.8ghz price:205$ | 1090t = 3.2ghz price:305$ Worth?
could you please post here which would you buy and why. Thanks
Well it kind is and isn't worth it for either. It depend on what you need out of the system.
Reason to get 1090T:
Easier to overclock (due to unlock multi),
Higher stock speed (for those that dont like to overclock but want the fastest cpu),
same power consumption as 1055t at higher speeds,
(may have this wrong but if i remember right) can achive slightly higher speeds than 1055t went overclocked.
Reason to get 1055t:
Cheaper
Can be overclocked to achive the same speeds as the 1090T.
Extra money that was saved can be put towards better gpu, ssd, more and/or faster ram.
Now which would i buy between the 2. For what i do, i would go after the 1055T as i can overclock it to the 1090t speeds and get it at a cheaper price. thus that would give me extra money to put it toward something else like maybe better GPU or an ssd.
SSD would improve overall system performance or a GPU can can improve games and/or gpgpu (General Processing on a GPU (graphic processing unit)) performance.
Now if you're rendering or something else that cpu intensive but doesn't use anything else much, then maybe 1090t.
