Mates,
This is not an overclocking question, but I figured the OC set would have more experience in hot memory. And I mean HOT!
I have a Dell Precision T5400 workstation (2009) > [Xeon X5460 QC @3.16GHz, 12GB DDR2-667 ECC, Quadro FX 4800, WD RE4 500GB, Segt Barac 500GB, 875W PS, Win 7 Ult 64 / BIOS is A11- probably about the latest] The RAM fills all 8 slots > 4,2,1,1,1,1,1,1, not optimum as it should be in 4's or at least in pairs. There is a case fan at the front pulling, a large 5 bladed fan blowing directly on the RAM, mounted on the back of a swing-out double HD carrier. The CPU has a large stacked plate cube heatsink with a fluid tube running through
it but no separate, special CPU fan.
As I am planning a big Solidworks and rendering binge, I bought a 2nd CPU, heatsink, and +4GB of RAM and I received the final part, the CPU heatsink today. The new RAM will be > 4,2,2,2,2,2,1,1. As I wanted to check the general health before adding the CPU and RAM, I downloaded and installed GPU-Z and CPUID Hardware Monitor.
The computer had been running for a couple of hours, streaming music and Internet. I was astounded when checking the CPUID Monitor -which lists the temperature of each RAM stick- to see one at 93 C or 197 F ! others were 65-75 C. The CPU was at 56 C and the GPU 54 C. "Fans PWN" showed all three fans at 35%
I immediately opened the case side, which has an intrusion switch. This switch is linked to the fan controller and if the case is open when starting up, there's a "Thermal Solution Compromised" error message and the fans go into a varying high speed mode- they really roar, also also vary in speed. If I replace the cover and reboot, the fans are at their normal, quiet level. At the moment, I replaced the cover and the fans have continued the high, varying speed. RAM temperatures are 53, 44, 50, 44, 40, 40, 48, 47 C - not so frightening and the CPU cores are 48,45,51,46 C, and FX4800 46 C. Even though they're roaring along, the fans still all show 35%
I've rebooted with the cover closed and the fans are quiet again, with the RAM temperatures climbing rapidly into the upper 60's.
I'm quite alarmed at this as of course this could have been going on along while. I didn't even know RAM could survive those temperatures. Is something is amiss with the fan controller ? Chassis intrusion switch ? Can the temperature monitor be wrong as the RAM is so hot while everything else shows more consistent temperatures? Is there a way to manually control fan speed- or even see the settings- so the fan near the RAM runs at some medium speed?
One RAM core is now 73C. CPU 55 C ,..
Of course, I won't be adding the CPU or RAM until this is solved. Should I not even use the computer with these temperatures?
Help!
Cheers,
BambiBoom
Help!
Cheers,
BambiBoom
