Hi, I planning on building a new system from scratch, and I am planning on using this motherboard:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128444 (GIGABYTE GA-880GA-UD3H).
I am getting only a single 6850 for the GPU as of right now, but I plan on using Crossfire with another 6850 in the future. I noticed that the MOBO has two PCIe 2.0 16x slots, but one of them runs at 4x. Would it still be a worthwhile to Crossfire even if the GPU's are running at 4x instead of 16x?
Thanks!
Thanks!
