Solved
GA-MA785GM-US2H CPU power question
I have a GA-MA785GM-US2H motherboard with an 8pin cpu power connector. Is it safe to plug in 2 4pin power connectors from the psu to fill both slots or should I just plug in the one 4pin. My cpu is an AMD 435 X3.
4 answers Last reply Best Answer
More about ma785gm us2h power question
  1. What is your PSU??
    If it is a 4+4 Pin ATX, it is okay. I'm not sure about two separate 4pin ATX, which is why I asked about your PSU.
  2. it is the Antec BP550 plus with a 4+4 connector
  3. Best answer
    You are good to go with plugging in the 4+4 pin into your motherboard.
  4. Best answer selected by ImWithStupid118.
Motherboards CPUs Power
