flyinfinni said:
Do you have a friend who has a different GPU you might be able to borrow? The reason I ask is that I'm wondering if maybe you are having an actual Motherboard problem as the likelihood of having 2 bad Radeon 5770s from 2 different companies that have the SAME problem, is EXTREMELY unlikely. If you could get a different card and try it, you could really prove there is nothing wrong with your cards. Or- do you have a different computer you could drop your cards into one at a time, and try them that way? If you can eliminate the GPU's completely from being your problem, you are a good step closer to getting things figured out.
Also- Another possible thing to try is to reformat/reinstall windows. I know thats a time consuming and irritating thing to do, but it can be worth it.
Ok, so where we so here is where we stand:
1. Eliminated the display as the issue- same problem shows on HDTV
2. We've Almost eliminated the GPU's- both giving the same problem individually points to something else.
3. We've mostly eliminated the drivers as you've tried many different versions, and even done the uninstall with Driversweeper before a reinstall.
4. your PSU should be way plenty of power.
Basically this leaves us with the following options:
1. Windows install/driver issues- requires a reformat/reinstall of windows to fix/verify.
2. Memory issue- requires running a memtest, possibly try running the computer and games with only one stick installed, and then try the other stick on its own.
3. A Mobo or CPU problem. If none of the above solve your issue, then this is sorta your last option. a problem here requires replacement of either one or the other or both of these parts. The reason this could be is that your problem could actually be the PCI-e lanes themselves, and the lanes are on the CPU die itself.
I have already reinstalled windows a few weeks ago to switch from 32 bit to 64, and it was showing this problem in the 32 bit as well.
I will also test the ram as well.
I'm also starting to think that it is a mobo problem as well, since I have tried all 3 of the lane slots and it's extremely unlikely that the both gpu's are at fault since they both show the exact same symptoms (and different companies).
I really would like to get a hold of another GPU, but I'm the only person I know who has a rig with a GPU. All my friends game on consoles, so they have built in graphics -_-.
