Yes No
Ads
Tom's Hardware > Forum > Motherboards & Memory > Motherboards > Chassis intruded fatal error system halted
Forum Motherboards & Memory : Motherboards Chassis intruded fatal error system halted
My PC show an error in startup "chassis intruded fatal error system halted"
please solve this error why this message is show in startup
My MotherBoard is "P5SD2-VM" ASUS
Reply to Navin Malik
Welcome to Tom's Forum! :)
Remove ANYTHING connected to or touching the CHA_DET {Chassis intrusion connector} on the MOBO; refer to your manual or download from -> http://www.asus.com/product.aspx?P_ID=napibCwKrjGDncvA page 1-30.
Message edited by jaquith on 12-22-2010 at 04:31:29 PM
Reply to jaquith
On the P5Q-E and some other Asus boards, there is no bios setting where you can turn intrusion detection off. Instead, you must locate the chassis intrusion pins and put a jumper on them. It is covered in the Asus manuals - download the manual for your motherboard.
Reply to compusolver
There are 1653 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Memory for GIGABYTE GA-G41MT-S2P
By fantastik250, 7 hours ago:
Take a look at this and see if you like it. http://www.newegg.com/Product/Prod [...]...
Best offers
Top experts
