Solved
Sleeving front panel connectors
Last response: in Components
June 21, 2010 7:07:01 PM
Hi, guys!
I would like to sleeve my front panel connectors (Power button, Power LED etc.). I have found some videos how to sleeve fan and molex cables, but I cannot find anything on FP connectors. Is it even possible to sleeve them? If yes, then how?
They make such a mess, everything else is sleeved so nicely.
Thank you!
Best solution
June 21, 2010 10:22:54 PM
It is possible. You just need to remove the connectors on the end of the cables. This can be done with a small hobby knife. If you look at the side of the connector, there is generally a small metal tab. If you push the wire into the connector a bit, then depress said tab, you can remove the pins. It often takes a bit of work.
BE SURE TO NOTE THE LOCATION OF EACH WIRE.
After you sleeve the cable, reattach the connectors.
a b ) Power supply
June 22, 2010 12:51:16 AM
You could also go with spiral wrap. It would negate the need to remove the connectors and gives a very neat look. Here is a link to a website showing it:
http://www.cabletiesandmore.ca/SpiralWrap.php
I have used it, it's excellent for nearly everything cable related.
m
l
a c 104 ) Power supply
June 22, 2010 6:16:32 AM
I wrapped/sleeved my cables in insulation tape once to keep them tidy, Black ofc :p
Moto
m
l
July 10, 2010 10:51:17 AM
Best answer selected by Anatorax.
m
l
