Hi
I've just put in 4gb DDR2 Ram (2 x 2gb)
System recognises just over 3gb (which I expected) and PC works fine, except no sound.
As far as I can see, it does not "see" any sound card so does not install drivers.
All I got in device manager is the std audio and legacy codecs but not the realtek HDA card it should see. Find new hardware fails to detect any card.
Tried to check BIOS to see if onboard audio still enabled but for some reason, although I can open the bios, can't use the arrow keys to adjust...it's as though the keyboard is dead. PS2 keyboard
Older computer..specs are
Windows XP SP3 32 bit
Foxconn K8M890M2MB Motherboard
AMDProcessor x86 Family 15 Model 67 Stepping 2 AuthenticAMD ~2599 Mhz
Radeon X1115 video card
Any advise greatfully received, even if to get into the bios adjustment so I can discount the thought that it's somehow changed.
Thanks for looking
Thanks for looking
