Need serious advice.! ordered the wrong hardware?
Hello! Well here is the thing. the problem is that i have ordered some hardware to build my own pc, and its coming in today.
Sadly enough, Today i found out that it's possible that the hardware all together isnt as stable as i thought it would and now im not sure if the memory is supported by the motherboard and if the holl picture will run?
Also on the Memory support list of gigabyte my memory doesnt come up there!
I hope u guys can tell me something about it and if the hardware that i ordered is working together ect??!
MotherboardGigabyte GA-X58A-UD3R, X58/ICH10R, S1366, ATX
Intel Motherboard SKT1366
ProcessorIntel i7-950, 3GHz, S1366, Box
Intel Processor SKT1366
Cpu CoolingNoctua NH-U12P cooling for s1366
MemoryCorsair 6GB (3x2GB) DDR3 SDRAM 6GB 1333MHz
DDR3 1333MHZ 6GB 3X240 DIMM UNBUFF. 9-9-9-24 MATCHED XMS3
PowerSupplyCorsair TX850W - Voeding ( intern ) - ATX12V 2.2 - 100-240 Volt wisselstroom V - 850 Watt - actieve
Btw: Why does people with the sam settings going for the 6gb 3x2 1600 instead of the 1333?
2 answers Last reply
More about need advice ordered wrong hardware
  1. Your board will work fine with a wide variety of ddr3; 1333 is fine. Some go with higher rated ram to overclock the cpu. But if you don't want to overclock the cpu, then you should be fine. With a voltage increase, some ram will overclock beyond their tested range, but that can shorten it's life.
  2. thnx man.seriously now im pretty sure of it.
    Btw: Ihave a PowerSupplyCorsair TX850W - Voeding ( intern ) - ATX12V 2.2 - 100-240 Volt wisselstroom V - 850 Watt - actieve
    I here a strange sound i think its coming from my Powersupply, hard to hear the sound is high and long. sometimes its sounds like a old dial up internet connection. sometimes it go's and come back or its stays for a wile..
    Doesn anyone know something about this?
Memory Hardware Motherboards
