Problem With GIGABYTE HD 5750
I Bought GIGABYTE HD 5750 and I Have Problem Frequencies fixed default frequencies in the sleep mode As the following form
My Computer
AMD Phenom II X3 720BE @ 2.8
MA78GM-US2H
RAM 2GB
HDD 500GB
Windows 7 32Bit
Driver ATI Catalyst 10.3 Preview
ATI GIGABYTE HD 5750
and i try to change driver same problem and change windows same problem
5 answers Last reply
More about problem gigabyte 5750
  1. Ok- Its a little hard to read your post and figure out what your problem actually is- let me see if I got this right. Your GPU is stuck at default frequencies even when the GPU is idle? You mean its not down-clocking to 2d clocks when its Idle?
    yes
    and sorry for my bad English
  3. No problem:-)
    Have you tried uninstalling your drivers, rebooting into safe mode and running driversweeper, and then rebooting and installing the driver again (or trying a different version of the driver like 10.2?)
  4. flyinfinni said:
    No problem:-)
    i will try but im change my windows and same problem
    okay what about temperature in the idle mode 49-50c
  5. Oh you reinstalled windows? Ok then, driver stuff probably isn't an issue then. I would probably contact the manufacturer then because Out side of drivers or the GPU BIOS, I don't know of anything else that would cause that. You might see if Gigabyte has an updated bios for your card, and RMA it with them (should still be under warranty I'd imagine)
Radeon Gigabyte HD Graphics
