I'm completely stuck. I've raised vcore, dropped vcore, rasied FSB, loosened timings, etc and I just can't seem to get past 3800MHz. I get a BSOD saying "uncorrectable hardware error" or "A clock interrupt was not received on a secondary processor within the allocated time interval." So I gave up and left it at 3.6GHz for a while.
Then yesterday, I ran prime for about an hour with no issues: 200x18.5 with vcore at 1.440, corsair dominator(CMD4GX3M2A) dual channel(currently unganged) at 1333mhz 10-10-10-24-34-2T @ 1.5v, NB and HT Link @ stock/auto
So today I raised the multiplier from 18.5 to 19 and got a rounding error within 5 minutes. So I thought I'd lower the freq a bit. I then lowered the multi back to 18.5 and then raised the FSB to 204 making it 3774mhz...BSOD "uncorrectable hardware error"
Ok, so I lowered it back down to what I had it at, tried prime again to see if I got the same results as yesterday(1 hour no errors), and within 5 minutes I got "fatal error: rounding was 0.484375, expected less than 0.4" on worker 3.
I'm just so confused as what to do now. Oh, and my temps are fine. Around 29C @ 3.6GHz and 50C on load with 1.440vcore
Thanks in advance.
CPU: AMD Phenom II x4 965 BE 3.4GHz
Motherboard: MSI NF980-G65
RAM: CORSAIR DOMINATOR 4GB (2 x 2GB) DDR3 1600 (PC3 12800) CMD4GX3M2A1600C8
PSU: Corsair TX950
GPU: Asus Radeon HD 6670 1GB
Cooling: Corsair H50 (7 toal fans including case fans, H50 fans, and GPU fan)
Case: Cooler Master Storm Sniper
Thanks in advance.
PSU: Corsair TX950
