Hey everyone,
I need help with my new PC build after thinking over my size and portability needs. I am in the process of putting together a high end AMD Phenom II X4 955/965 gaming rig with either an ATI 5870 (if prices go below $400 anytime soon) or an ATI 5850. Originally I had built a PC with an NZXT Hades case in mind but realized that it would not be very portable or space friendly. Thus, I have decided on the following build but need help identifying the best possible Micro ATX case out there along with the best low profile CPU cooler. I would prefer a case with the best possible airflow and lightness but airflow comes first.
It must be noted that I do plan on overclocking to the highest degree on stock voltage which should be somewhere between 3.6-3.8 ghz while also having the ability to upgrade to crossfire in the future (thus, overclocking the video cards is unnecessary).
MSI 890GXM-G65 - $125
ATI 5850/5870 - $300-$420
Seasonic X750 - $180
AMD Phenom II X4 955/975 - $160-$180
G.Skill Ripjaws Series 7-8-7-24-2N CAS 7 - $120 (might need to re-think this, heatsinks might get in the way)
Samsung Spinpoint F3 1TB - $90
Sony Optical Drive - $22
Gigabyte GM-M8000X Mouse - $60
Micro ATX case - ??????????? NZXT Rogue, Lian-Li PC-V351, Silverstone SG03, Thermaltake Lanbox, etc.
Low-Profile CPU Cooler - ??????? Scythe Shiruken, Zalman, etc.
I know this build might seem a bit impossible to do with good cooling but I'd really like to try to find something that suits my needs without having to sacrifice anymore.
Also, if you have any better suggestions on the parts I've already selected please feel free to give your opinions.
Thanks!
Thanks!
