XP/ME Network problem
Last response: in Windows XP
Archived from groups: microsoft.public.windowsxp.configuration_manage (More info?)
I have two machines that I would like to network using a crossover cable but
am having problems.
Basically, I can't get the 2 Machines to see each other.
I have run Network Setup wizards to no avail. I have scoured the net for a
way to solve my problems and tried numerous suggestions, still no luck.
Many places on the Net state that setting up a simple network between two
Windows machines using a crossover cable is easy!!! I have considered buying
a Hub but for all I know (not a lot but learning fast) I may well be no
better off. Any suggestions would be most welcome.
Here are the details:
Machine 1
OS: XP Home
NIC:
VIA Rhine II Fast Ethernet Adaptor (built into the Motherboard).
Selecting properties of the NIC in Device Manager, the settings are as
follows:
Advanced Tab:
Adaptive Interrupt: Enabled
Connection Type: Auto-Negotiation
Flow Control: Hardware Default (Auto)
Network Address: Not Present
Receive Buffers: 64
Transmit Buffers: 64
When viewed through Network Connections it shows:
Name: Local Area Connection
Type: LAN or High-Speed Internet
Status: Connected
Device Name: VIA Rhine II Fast Ethernet Adaptor
If I right-click on this it shows the following Local Area Connection
Properties:
General Tab: Client for Microsoft Networks (ticked)
File & Printer Sharing for Microsoft Networks
(ticked)
Internet Protocol (TCP/IP) (ticked)
Properties for this are:
Use the following IP Address: (Selected)
IP Address: 192.168.0.1
Subnet Mask: 255.255.255.0
Default Gateway: Blank
Use the following DNS server address: (Selected)
Preferred DNS Server: Blank
Alternate DNS Server: Blank
Authentication Tab: Enable IEEE 802.1x. (ticked)
EAP Type: Smart Card or other
certificate
Authenticate as computer when computer
information is available (ticked)
Authenticate as guest when user or
computer is unavailable (ticked)
Full Computer Name: MACHINE1
Workgroup: MACHINES
IPCONFIG Results:
Windows IP Configuration:
Host Name: Machine1
Primary DNS Suffix: Blank
Node Type: Unknown
IP Routing Enabled: No
WINS Proxy Enabled: No
Ethernet adaptor Local Area Connection:
Description: VIA Rhine II Fast
Ethernet Adaptor
DHCP Enabled: No
Various drives/folders are set as Shared
Firewall is off.
This machine also has a ADSL Broadband Internet connection via a USB Modem
Machine 2
OS: WinME
NIC:
SMC EZ Card 10/100 (SMC1211TX)
When I select Network within Control Panel the following is displayed:
Configuration Tab: Client for Microsoft Networks.
Properties for this are: Logon and
restore Network connections (selected)
Microsoft Family Logon
Driver Type Tab. Click the type of the
network driver to use:
All greyed out - nothing selected
Bindings Tab: TCP/IP (ticked)
Advanced Tab: Link Speed/Duplex Mode: Auto Mode
Network Address: Not present
TCP/IP
IP Address Tab: Specify an IP Address (selected)
IP Address: 192.168.0.2
WINS Config Tab: Disable WINS Resolution
Gateway Tab: All Blank
DNS Config Tab: Disable DNS
NetBIOS Tab: All greyed out but 'I want to enable NetBIOS over
TCP/IP protocol' is selected
Advanced Tab: Allow binding to ATM. Yes is selected
Bindings Tab: Client for Microsoft Networks (ticked)
File and Printer sharing for MS Networks
(ticked)
MS Family Logon (ticked)
Browse Master: Automatic
LM Announce: No
Full Computer Name: MACHINE2
Workgroup: MACHINES
Firewall is off.
IPCONFIG Results:
Host Name: Machine1
DNS Servers: Blank
Node Type: Broadcast
NetBIOS Scope ID: Blank
NetBIOS Resolution Uses DNS: No
0 Ethernet Adaptor:
Description: NDIS 5.0 driver
DHCP Enabled: No
Primary WINS Server: Blank
Secondary WINS Server: Blank
More about : network problem
Not only do you have to connect the crossover cable to the two machines, but
also the following, The magic network faries have been on strike for what
seems like forever :) :
1. Set IP address on first machine to something like 192.168.0.1 and the
second machine to 192.168.0.2. And change your subnet to 255.255.255.0
2. Set your computer names differently. i.e. winxp machine and winme
machine.
3. Set your computers to the same workgroup. default in XP is MSHOME.
4. turn on printer and file sharing on both PCs
5. disable your firewalls, this will allow you to make a connection without
any ports blocked. If your network is ok after all this the re-enable your
firewalls to see if everything still works, if not then you will have to
manually configure your firewall software.
6. right click on your drives/folders/files you want to share and enable
sharing...
Robert...
That should allow you to connect
"Ben Hardy" <bh@hb1.com> wrote in message
news:cqq4he$c6r$2@newsg2.svr.pol.co.uk...
>but am having problems.
> buying a Hub but for all I know (not a lot but learning fast) I may well
> be no better off. Any suggestions would be most welcome.
> Machine 1
> OS: XP Home
> NIC:
> follows:
> Advanced Tab:
> Receive Buffers: 64
> Status: Connected
> Properties:
> (ticked)
> certificate
> Workgroup: MACHINES
> IPCONFIG Results:
> Host Name: Machine1
> Node Type: Unknown
> Ethernet Adaptor
> DHCP Enabled: No
> Firewall is off.
> Machine 2
> OS: WinME
> NIC:
> TCP/IP
> Networks (ticked)
> LM Announce: No
> Workgroup: MACHINES
> Firewall is off.
> IPCONFIG Results:
> Host Name: Machine1
> DNS Servers: Blank
> 0 Ethernet Adaptor:
> DHCP Enabled: No
Ask the community
