Hi all,
So I've just built a new system using a Hyper 212, Gigabyte Sniper 3 motherboard, and Core i7 3770k. I've overclocked it to 4.5 GHz by just upping the turbo multiplier to 45. I have VCore set to "Normal" (not sure what that means for Gigabyte but it allows me to change Dynamic VCore). However, I actually ended up gaining stability with the dynamic part set to 0. My max temp for 1 core only is 91 C (average is around ~85) which feels a little high. How should I go about lowering this? Should I change "Normal" to a specific voltage? Oh and I did reset the CPU cooler right before this test so the temps may lower some over time.
Here is a screenshot:
Also is it best to overclock Turbo multiplier and not Core multiplier? I want it to scale and not use as much power when I'm not gaming.
Edit: Screenshot isn't working...here is the link
http://imageshack.us/photo/my-images/18/screenshot1gi.png/
