New amd system advice
HELLO EVERYBODY....I am gonna purchace a new system within 20 days .. so plz help me out ..
following is on my list ....any suggestiions are welcome.... i would stick to amd only...
PROCESSOR-AMD PHENOM™ II X4-965BE(3400MHZ)-125W--
MOTHERBOARD-GIGABYTE - GA-790FXTA-UD5
GRAPHIC CARD - SAPPHIRE ATI RADEON HD 5850
RAM- G-SKILL RIPJAWS DDR3-1600 PC3-12800 CL7-8-7-24 (2X2GB)
CABINET-
COOLER MASTER 690 II ADVANCED. OR COOLER MASTER HAF 922
SMPS - CORSAIR 750W HX OR TX
HARD DISK - 1 TB SATA-WD/SEAGATE
6 answers Last reply
More about system advice
  1. Might want to follow the guidelines to get the best advice. There's a link in my signature.
    Get the X4 955. It's the same chip, just without a factory overclock. It's going to be about $25-40 cheaper.
    Switch the board to the 790XTA-UD4. It'll save some more money.
    Make sure that HDD is the Seagate 7200.12 1 TB. The older models are slower and unreliable. Or you could also get the Samsung Spinpoint F3 1 TB.
  2. THANX MADadmiral.....but 965be faster and 790fxta -ud5 is latest . price no matter..........i will take seagate7200.121 tb .ok . any other suggestions...about ram or psu?
  3. The 965 is faster at stock speeds. However, it's the same physical chip as the 955. That means you can save some money, buy the X4 955 and apply a slight overclock and have the same thing as the 965. You don't even need an aftermarket cooler to get the same speeds.
    Also, the 790FXTA-UD5 is NOT the latest. Any of the 890GX boards are the newest AM3 CPUs, and the only difference with the 890 chipset is they won't need a BIOS update to use the upcoming six core CPUs.
    The differences betwen the UD4 and UD5 are:
    UD5 has an extra PCIe 2.0 slot, which doesn't do anything as Crossfire doesn't scale well past two cards.
    UD5 has 16x/16x on the first/second slots, which is only a 4% performance gain over 8x/8x and only noticeable with HD 5970s
    UD5 has two exta USB 2.0 ports in the back
    UD5 is $55 more expensive
    So basically, you're paying $55 more and not getting anything for it.
    RAM is fine. A slightly cheaper PSU would be the Antec Earthwatts 650W, the Corsair is still good.
  4. If you get the 955, get the C3 chip not the C2 chip. Even so, remember that a 955BE C3 is a chip that didn't cut it to be a 965BE running at default voltage. As long as you have a good cooler though, the general difference in their over clocking ability is small. Of course, it all depends on your particular sample how far you get :D.
  5. Yeah no real point to get the 965, but if you insist just go with it. If you do choose to get the 955 remember what megadmanx00 said and make sure you get the C3 stepping version. the product number will end in MBOX if it's C3. Also if you don't want to overclock the 955 I'd advise going into bios and lowering the stock voltage. The 955 comes stock at 1.4v i think but i run mine at 1.32(or something around there) and it runs a lot cooler(been running like that for 1-2months and no problems, but not needed if you use an aftermarket cooler which i dont, yet.). As for the motherboard I'd suggest the GIGABYTE GA-890GPA-UD3H. Newest chip set and a bit cheaper. It runs magnificently.
    CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819103808&cm_re=955-_-19-103-808-_-Product
    MOBO: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128435&Tpk=890gpa
  6. thank u to all of u for ur reply.
    GIGABYTE GA-890GPA-UD3H OK.SAW THAT on net.would it be enough for downloading ,surfing ,high end games,dolyby surround music
    .. want to ensure that i would not upgrade y pc for atleast 3 years would all the combinations work ok . i mean the cpu 965-125w,GIGABYTE GA-890GPA-UD3H motherboard , ram and sapphire 5850 , and corsair psu... what abt the case cooler master 690 advanced 2..
    also suggest some 24 inch hd lcd monitor .....
New Build AMD Systems Product
