Archived from groups: comp.sys.laptops (More info?)
I have a Dell Latitude CP laptop, PII 233, with docking station. For
the last few months, the computer is able to work only when it has AC
power supply connected. The battery LED indicates it is fully
charged, but if the AC is removed the computer won't boot.
I would think that if the battery wasn't connected to its power lines,
it would eventually lose it charge, but it has been fully charged
this entire time.
Can anyone tell me why the battery seems to be able to charge itself,
but not supply power to the computer? Any fixes?
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi Mark,
How old is the battery?
Ciao . . . C.Joseph
That which a man buys too cheaply . . .
~ He esteems too lightly
|this entire time.
|thanks
|Mark
|Toronto
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.2 (MingW32)
> this entire time.
> thanks
> Mark
> Toronto
As the battery ages, the charge capacity declines, appearing finally at
fully charge with a capacity too low to supply power. There is no fix
except for a new battery. You should remove a dead battery unless you
need it to couterweight the screen.
> this entire time.
> thanks
> Mark
> Toronto
The lights on the battery show what the battery gauge chip tells them.
If the chip is (too far) out of sync with the battery charge level, the
system won't run.
Sometimes there's a calibration routine that can fix that.
You don't say what battery technology you have. Lithium Ion Batteries
typically fail with high internal resistance. The charge is in there,
you just can't get it out at a voltage that will run the computer.
The battery lights will show there's full charge...and there is...but
when you turn on the computer the internal resistance causes a voltage
drop that the laptop interprets as a dead battery and shuts down.
mike
Return address is VALID.
Wanted, 12.1" LCD for Gateway Solo 5300. Samsung LT121SU-121
Bunch of stuff For Sale and Wanted at the link below.
Compaq Aero floppy,ram,battery.
MINT HP-41CV, 2-METER AMPS, 200CH SCANNER
http://www.geocities.com/SiliconValley/Monitor/4710/
this entire time.
thanks
Mark
Toronto
I have the same problem, but my battery is new. It is a Dell Inspiron E1505 with a new McVolt high capacity battery. Any clues what has gone wrong?
