I am not big on overclocking. I don't mind spending whatever I need to in order to have the fastest quietest system available. I have run computers on both water and air. I thought that by using water, I could eliminate most of the sound generated by the case, cpu and gpu. What I found though was that by the time I set up everything I needed to cool my system with water, the sound generated by a push pull configuration was substantial and negligible noise savings.
It has been about 5 years since I last tried this. The pc I am currently using utilizes a Fractal Design Define XL case and an after market cooler for the cpu while leaving the two 680 gtx on factory air. Can someone tell me whether it makes sense to use a water cooled system if only used for the quietest gaming experience without headphones possible? If I have no need to overclock and I still obtain a lower db on water than air? Thanks.
