Help cooling phenom quad core processor
I recently ordered this http://www.newegg.com/Product/ComboBundleDetails.aspx?ItemList=Combo.415764 and just today realized the cpu doesnt come with a heatsink or fan so i was wondering if I should buy a cooling fan for it if so would this be good enough http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4557678&CatId=493.
7 answers Last reply
More about help cooling phenom quad core processor
  1. Best answer
    you current heatsink will work, how hard do you plan to push the CPU?
    if you plan to over clock or spend hours gaming then i would look for something better. for business use or surfing the web, you are fine. it will run warm, just keep an eye on it with HWmonitor software.
  2. i wont be overclocking but i will be playing games on it the most demanding one being starcraft 2 on the highest settings possible
  3. if you dont plan on oc'ing, any stock fan is good enough. the stock fans are meant to adequately cool the cpu, and even give a small amount of oc'ing headroom.
  4. yes, i know, its oem, it doesnt come with a "stock" fan, but that fan is about as good as a "stock" fan, so im just calling it stock lol, sorry for any confusion.
  5. alright thanks for the responses
  6. Best answer selected by stabito.
CPUs Cooling Quad Core Fan Processors Product
